11-Garnet
How to move a column in table?
I am using CREO 10.0.7.0 and on the drawing sheet. I have to edit a bom table .tbl file to modify the template to my needs.
I want to move a column or copy and paste the contents to a new column created at the desired position.  I also want to edit the column width to match text size automatically.
How can I do this task?
Community Moderator
Hi @Shumayal,
Thank you for your question.
Anurag
Shumayal11-GarnetAuthor
11-Garnet
Thank you however it appears that basic table functions such as the one that I requested isn't possible in CREO like a word processor or excel. In the end, I just got around the problem by redoing the entire table since moving columns or copying them isn't supported apparently.
