Jul 7, 2017 11:32 AM UTC
HOW TO OPEN FAMILY TABLE INSTANCES OF A PART MODEL USING AUTOMATION.
Hello Everyone.
I am having a sheet metal part which is having lot of family table members. What i want to know is when we open this part manually in creo first it will pop-up the full list of members with genric item so that we can open any perticular instances.
But how is this possible through VB-API. I am able to open the model and its asking to choose the reps but i am not able to get the family table list.
I tried the below codes:
Dim descModel As IpfcModelDescriptor
Dim options As IpfcRetrieveModelOptions
Dim model As IpfcModel
options = (New CCpfcRetrieveModelOptions).Create
options.AskUserAboutReps = True
descModel = (New CCpfcModelDescriptor).Create(type, instance, Nothing)
descModel.Path = stdPath
model = session.RetrieveModelWithOpts(descModel, options)
retrieveModelFromStdDir = model
But in this case i have to specify which instance i want to open. But its again a time consuming process right.
So is there any way so that when i open the part by default it should list the family members so that i can open the mode.
Any suggestion's will be very helpfull for me.
With Regards
Aghil.M
