Mar 5, 2018 10:39 AM UTC
How to pass command line arguments or print to the command line using creo toolkit application
I am using Creo 2.0 and Creo Parametric Toolkit that comes with this version.
This is my user intitialize from my code.
int user_initialize(int argc,char *argv[],char *version,char *build,wchar_t errbuf[80])
char *dateCode;
ProEngineerDisplaydatecodeGet(&dateCode);
printf("%s", dateCode);
return (0);
But this does not print anything on the command line. In Utilities -> Auxilliary applications my application is shown to have started.
Also please suggest to to pass command line arguments to my custom application. Please give a sample example of how to pass command line arguments corresponding to my code.
Lets say My application's .dll file is in C:\Application directory. The protk.dat file is also in that directory.
I am launching creo from command line with the following command.
cmd
C:\Application><Creo_Install_path>\Parametric\bin\parametric.bat
Do I have to add anything after the parametric.bat statement or do what ? Please give a sample example of how to pass command line arguments corresponding to my code.
Mar 5, 2018 12:08 PM UTC
Hi
You need to use ProMessageDisplay() to print in message area.
There is lot of samples available in protoolkit directory in the Creo installion folder.
