How to pass _ModelItemType_null as argument of wfcComponentFeat.AssemblyItemInstructions_Create
Hi All,
I'm playing with flexible component in otk.
I'm able to set as a flexible component in the case when the flexibility of the part was done by dimensions (ModelItemType.ITEM_DIMENSION).
Part of my code:
 AssemblyItemInstructions ThisAsmInstr = wfcComponentFeat.AssemblyItemInstructions_Create(ItemOwner,
ModelItemType.ITEM_DIMENSION, dim_id_array.get(i));
Question is: what is the proper syntax of ModelItemType argument, to get parameter??
There is written in "Creo Object TOOLKIT Java User's Guide 7.04.0" page 494:
(...)wfcComponentFeat.wfcComponentFeat.AssemblyItemInstructions_Create creates a new instance of the object wfcAssemblyItemInstruction that contains the instructions to define a variant item for a flexible component. Specify the model owner, item type, and item ID as input arguments of this method. The input arguments are:
• ItemOwner— Specifies the model owner of the item or parameter.
• ItemType— Specifies the item type. The value of this argument is ignored for
parameter. For parameter, pass this value as _ModelItemType_null.
• ItemId— Specifies the item identifier.
• ItemName— Specifies the parameter name.
Any idea how it should be used??
