how to program to incorporate this line ~ Input `file_open` `Inputname` `xxxxxxxxxx` into trail file
- 1 reply
- 1600 views
- Translate All
Hello Mr Martin,
Yes with further study of trail files and basic programming, I could successfully extract and modify trail file for .prt import and .stp export for two part files.👍..I could also write a program in Basic to generate trail file. However, just one question is there --
ie how to program to incorporate this line- ~ Input `file_open` `Inputname` `xxxxxxxxxx` into trail file? Sharing trail file and basic program (in .txt format/I had written it in qbasic only, which has been converted to .txt here) herewith.
Requesting for the solution,
Thanks in advance!
