Apr 12, 2017 7:26 AM UTC
How to record Check-out OK Button for mapkey?
I am trying to record a mapkey for performing automatic check-out of objects in Creo Parametric, but I can't manage to record the string for the OK Button which confirms the object to be checked-out:
After recording, the recorded mapkey just shows the command to click check-out...
Anyone has already did it? or an idea on how to?
    tleatiAnswer
    Apr 12, 2017 4:04 PM UTC
    Hi Stephen,
    thanks for your reply. No, it doesn't work on my Parametric 2.0, as it doesn't write anything for performing the "Accept value" button.
    But I have just solved the problem!
    It was simpler than thought: you need just to tick on "Accept system default" in the mapkey definition dialog box:
    this will indeed add a space and a ";" at the end of the script:
    mapkey o @MAPKEY_LABELcheck-out;~ Command `ProCmdMdlTreeWfEdit`; ;
    (which probably means "accept system default"...).
    I think in these cases (in the 2.0) it doesn't script anything for the green tick just because it sees it as an input field (so the mapkey itself interrupts).
    Bye
    StephenW
    Apr 12, 2017 3:55 PM UTC
    Doesn't a simple "enter" work? It works on mine.
    tleati12-AmethystAuthorAnswer
    Hi Stephen,
    Bye
