11-Garnet
Apr 30, 2026 5:22 AM UTC
How to remove the attached notes
Hi everyone, I am trying to remove the attach notes from drawing view, anyone knows how to do that.
I tired using ProDtlnoteErase with that it will erase the note until next regeneration.
Please refer the picture (I want to remove the SCALE 3:1 note) and the code.
void glass_drawing_anote::RemoveNotes(void* app_data,
const std::string& target_view,
const std::string& target_note)
ProDrawing drawing = (ProDrawing)app_data;
ProError err;
ProDtlnote* p_notes = NULL;
int n_notes = 0;
// Collect all notes
err = ProDrawingDtlnotesCollect(drawing, NULL, PRO_VALUE_UNUSED, &p_notes);
if (err != PRO_TK_NO_ERROR || p_notes == NULL)
return;
ProArraySizeGet((ProArray)p_notes, &n_notes);
for (int i = 0; i < n_notes; i++)
ProDtlnotedata note_data = NULL;
if (ProDtlnoteDataGet(&p_notes[i], NULL,
PRODISPMODE_NUMERIC, &note_data) != PRO_TK_NO_ERROR || note_data == NULL)
continue;
// Get attachment info
ProDtlattach attach;
if (ProDtlnotedataAttachmentGet(note_data, &attach) != PRO_TK_NO_ERROR)
ProDtlnotedataFree(note_data);
continue;
ProDtlattachType type;
ProView note_view = NULL;
ProVector location;
ProSelection attach_point;
ProDtlattachGet(attach, &type, &note_view, location, &attach_point);
ProDtlattachFree(attach);
if (note_view == NULL)
continue;
// Get view name
ProName view_name;
if (ProDrawingViewNameGet(drawing, note_view, view_name) != PRO_TK_NO_ERROR)
continue;
char view_name_str[PRO_NAME_SIZE];
ProWstringToString(view_name_str, view_name);
// Get note text
std::string note_text = "";
ProDtlnoteline* p_lines = NULL;
if (ProDtlnotedataLinesCollect(note_data, &p_lines) == PRO_TK_NO_ERROR)
ProDtlnotetext* p_texts = NULL;
if (ProDtlnotelineTextsCollect(p_lines[0], &p_texts) == PRO_TK_NO_ERROR)
ProLine string;
ProDtlnotetextStringGet(p_texts[0], string);
char text_str[PRO_LINE_SIZE];
ProWstringToString(text_str, string);
note_text = std::string(text_str);
ProArrayFree((ProArray*)&p_texts);
ProArrayFree((ProArray*)&p_lines);
// Match both view and note text
if (std::string(view_name_str) == target_view &&
note_text.find(target_note) != std::string::npos)
err = ProDtlnoteErase(&p_notes[i]);
err = ProDtlnotedataDisplayedSet(note_data, PRO_B_FALSE);
if (err == PRO_TK_NO_ERROR)
logger::log_info("Removed note in view [" + target_view +
"] with text: " + note_text);
else
logger::log_info("Failed to remove note in view [" + target_view +
ProArrayFree((ProArray*)&p_notes);
int num_sheet;
ProDrawingCurrentSheetGet(drawing, &num_sheet);
ProDwgSheetRegenerate(drawing, num_sheet); // when I regenerate the notes come back, ProDtlNoteRemove is not working for these type of notes.
kdirth
May 1, 2026 4:11 PM UTC
Maybe erase would work better to eliminate regeneration of it.
KenFarley
May 1, 2026 5:13 PM UTC
Don’t know if it’s important or not but you’re ignoring the result of the
function call. What if it’s returning an error code?
Also, I’m not a Creo app programmer, but a quick check of the manuals seems to imply that it might be possible to use
ProDtlentityErase
But I’m naive about the way these things are done, so maybe that’s the wrong thing to use for what you’re after. I just wonder if the scale “note” might be some sort of special thing and not a simple detail note, since it’s generated by Creo and not created by the user?
11-Garnet
May 8, 2026 8:27 AM UTC
Hey, you are correct I am getting error for the attached notes, do you have any solution for this,
thank you for the reply
