6-Contributor
How to select geometric entities like datum plane using ProSelect().
While using ProSelect() i am unable to select datum plane from creo parametric window.
Help me out if any anyone has solutions to this problem.
Hi @AI_10095062
did you specifiy the correct filter option:
status = ProSelect("csys", 1, NULL, NULL, NULL, NULL, &sel, &n_sel);
all possibl option on Creo Parametric Toolkit user guide User guid page 509 - believe 8 version:
https://www.ptc.com/support/-/media/support/refdocs/Creo_Parametric/8,-d-,0/tkuse_Creo8000.pdf?sc_lang=en
One more note: filter string for Datum plane - "datum"
 Because I did answer  a post with searching some  csys' did mentnioned the wrong filter. Thanks for the clarification.
