How to set a background image in the user interface by using the creo ui editor?
Hi All,
I am developing an user interface for protoolkit application by using the creo UI editor. As the creo ui editor is structured in a grid form, I could not set a back ground image in the created application UI. The background image is required to add some labels on it.
Kindly suggest some ideas.
Thank you!
Hello!
I think, you can use Drawing Area component. But only in programming way (not in UI Editor) you can place background image and labels on it. For example, like Shape tab in Hole feature.
Hello
Thanks for the suggestion! I will check on the same and will share the results and observation.
