How to set material in a part with excel vba
I've searched everywhere for an example of this, and am coming up zeros. The only thing I've found is this article:
https://www.ptc.com/en/support/article?n=CS148500
... and it doesn't work at all. (The "session" object isn't even instantiated in the example).
Here is what I'm doing:
' Dim statements
' connection stuff
... Set oModelDescriptor = oModelDescriptorCreate.Create(ModelType, ModelName, Null) Set oModel = oSession.RetrieveModel(oModelDescriptor)
blah blah
' do some stuff
All of that ^ works fine, as I can read/set parameters, etc.
I can also read the current material with this:
' get material
If oModel.Type = EpfcModelType.EpfcMDL_PART Then
 Set part = oModel
 Set material = part.CurrentMaterial
 .Cells(iRow, colOriginalMaterial).Value = material.Name
End If
But I'm not having any luck at all setting a new material. I'm trying something like this, but nadda (oModel is set earlier in the procedure):
' Set material
Dim part As IpfcPart
Dim material As IpfcMaterial
Set part = oModel
Set material = part.RetrieveMaterial("steel.mtl")
part.CurrentMaterial = material
Any help?
cstarnes12-AmethystAuthor
Helllooooo.......   is this thing on?
Does anyone ever actually answer questions here? I don't think I've ever had a single response.  🙂
Maybe Creo can't found mtl file.
Try manually add new material from mtl into part.
Then use GetMaterial (Name as string). This function return IpfcMaterial. And then set this material to the part properties
PS: in PTC case material = part.RetrieveMaterial("Iron") loading material by mtl file name WITHOUT extension .mtl. In your code you using name with extension
- Specifies the material. calculate the weight
- Material file extension is not used
- Modify the code and use
Set oModel = oSession.CurrentModel
Set oSolid = oModel
'// config.pro option
Call oSession.SetConfigOption("pro_material_dir", Worksheets("data").Cells(20, "B"))
Call oSession.SetConfigOption("mass_property_calculate", "automatic")
Dim oPart As IpfcPart
Dim oMaterial As IpfcMaterial
If Worksheets("File Info").Cells(6, "E") Is Nothing Then
MsgBox "Please select a material file", vbInformation, "ToolBOX VBA"
Exit Sub
ElseIf Worksheets("File Info").Cells(6, "E") = "prt" Then
Set oPart = oModel
Set oMaterial = oPart.RetrieveMaterial(Worksheets("File Info").Cells(12, "C"))
Worksheets("File Info").Cells(13, "C") = oMaterial.Name
oPart.CurrentMaterial = oMaterial
Else
MsgBox "Not a part file", vbInformation, "ToolBOX VBA"
Exit Sub
End If
'// SET Regenerate
Dim RegenInstructions As New CCpfcRegenInstructions
Dim oInstrs As IpfcRegenInstructions
Set oInstrs = RegenInstructions.Create(False, False, Nothing)
'// Regenerate 실행
Call oSolid.Regenerate(oInstrs)
'//Mass
Dim oMassProperty As IpfcMassProperty
Set oMassProperty = oSolid.GetMassProperty("")
Worksheets("File Info").Cells(17, "C") = oMassProperty.Mass
MsgBox "Part file weight was calculated", vbInformation, "ToolBOX VBA"
End Sub
