Nov 5, 2018 3:54 PM UTC
How to set model view with VB API?
Is there a way to set the model orientation to a named view using the VB API? All I can find in the docs is some information on drawing views.
I have an Excel spreadsheet set up as a model configurator, and need to set the view to "Default" or some other defined view after setting model parameters and regenerating.
Dec 24, 2018 3:55 AM UTC
Hi, please find mapkey string which can be called from VB API.
session.RunMacro("~ Command `ProCmdNamedViewsGalSelect`  `RIGHT`;")
Instead of "RIGHT", you can write your named view's name.
Jaykishan
Dec 13, 2018 1:34 PM UTC
I guess there is no such VBAPI function. but you can send a Creo command with Mapkey in VB API, as a work around.
Jaykishan
