How to set tessellation control parameters
I have the set tessellation parameters as below:
  • step size is assigned with model size ( diagonal of the bounding box ) / 30.
  • chord height is set by fetching the model accuracy using the GetAbsoluteAccuracy() method.
  • Angle control is set to 1.
I am not getting a better result using this. The quality and the curves or circles in the model are not accurate.
I am using creo parametric object toolkit version 8.0.2.
Hi
You need assistance in setting Creo OTK to tesselate a model.
First can you confirm your application export to STL indeed?
If yes, have you found the settings that you need from the User Interface.
Reminder: Toolkit relies on existing UI commands. Once your UI command workflow is defined then you have your footprint to code.
Upon exporting the model in STL it's working fine.
