Nov 6, 2012 2:55 AM UTC
How to set the color property of a surface using j-link ?
As a beginner , I konw this question maybe stupid ,but I've already checked almost all the file that I can get.
I want to mark some of the surfaces in the model using a color, and the rest of surfaces using the other color.
And, I already successfully got a sequence of "item", but I didn't find any information about how to operate these items in color or material .Will someone give me some suggestion ? Thank you !
ysinitsinAnswer
Nov 13, 2012 2:51 AM UTC
First of all, I'm not sure, that is possible to run a macro from config.pro. This method is working fine, for example
proESession.RunMacro("mapkey $F2 ~ Activate `main_dlg_cur` `page_Review_control_btn` 1;"+
"mapkey(continued) ~ Activate `main_dlg_cur` `Review:ProCmdDwgRegenDraft`;"+
"mapkey(continued) ~ Activate `main_dlg_cur` `page_Tools_control_btn` 1;");
Working code:
Model Doc3D;
SelectionBuffer selectionBuffer;
Session session = pfcGlobal.GetProESession();
selectionBuffer = session.GetCurrentSelectionBuffer();
Doc3D = session.GetCurrentModel();
ModelItems Faces = Doc3D.ListItems(ModelItemType.ITEM_SURFACE);
Selection Sel = pfcSelect.CreateModelItemSelection(Faces.get(1), null);
selectionBuffer.AddSelection(Sel);
session.RunMacro("mapkey $F8 ~ Select `main_dlg_cur` `View:ProCmdViewGallery`;"+
"mapkey(continued) ~ Close `main_dlg_cur` `View:ProCmdViewGallery`;"+
"mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewGallery_layoutph.appEditorPB`;"+
"mapkey(continued) ~ Activate `pgl_appearance_manager` `ColorButton` 1;"+
"mapkey(continued) ~ Arm `pgl_color_editor` `SBlue`;"+
"mapkey(continued) ~ Update `pgl_color_editor` `SBlue` 100;"+
"mapkey(continued) ~ Disarm `pgl_color_editor` `SBlue` 100;~ Arm `pgl_color_editor` `SGreen`;"+
"mapkey(continued) ~ Update `pgl_color_editor` `SGreen` 0;"+
"mapkey(continued) ~ Disarm `pgl_color_editor` `SGreen` 0;~ Arm `pgl_color_editor` `SRed`;"+
"mapkey(continued) ~ Update `pgl_color_editor` `SRed` 0;~ Disarm `pgl_color_editor` `SRed` 0;"+
"mapkey(continued) ~ Activate `pgl_color_editor` `StdOk`;"+
"mapkey(continued) ~ FocusOut `pgl_appearance_manager` `AppearanceName`;"+
"mapkey(continued) ~ Activate `pgl_appearance_manager` `stdOk`;");
In the example, will change the color only ONE face of the part. I don't like a flashing window. Need to play with a macro.
Nov 7, 2012 2:09 AM UTC
Oh , no ... Anybody can provide some help ?
Nov 7, 2012 7:09 AM UTC
Thinking out loud. Try to make a mapkey (macro) for changing a color of selected face. Then use pfcSession.BaseSession.RunMacro
Nov 7, 2012 1:51 PM UTC
Thank you ~ I'll try that tomorrow ~
Nov 9, 2012 3:23 AM UTC
How is going?
I think, first of all need to select (visual selection in working space) item/surface of a part and then use runmacro.
By the way, can you share a part of code where you got a sequence of "item"?
