How to setting Orbit Constraint in Creo Parametric?
Hi
I google method to set Orbit Constraint Navigation in Creo Parametric but there're no guide.
Are there this setting in Creo Parametric?
Thank
Travis
@TravisDesigner wrote:
Hi
Thank
Travis
please described, what is Orbit Constraint Navigation.
Hi Martin;
When you use mouse to Orbit, they will keep the ground and rotate the view around object. In other software as Fusion 360, It's called Orbit Constraint.
Hi Martin;
please try Fly Through mode.
See http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals%2Ffundamentals%2Ffund_four_sub%2FTo_Fly_Through_a_Model.html%23 help page.
