Jun 25, 2014 5:29 PM UTC
How to show the same component in new rep from the existing rep without excluding in asm?
In assembly I have four representation including master rep like
a , b, c & D
a= master rep
The rep "A" has set of components including parts & sub asm like
1
2
3
4
5
6
7
The rep "B" has components like
1
2
3
8
9
10
11
12
And the rep "c" has
1
2
3
11
12
25
27
In "D" has the same componts like what "C" holds
1
2
3
11
12
25
27
My question is that when I am creating a D rep , all the components are adding from A,B, C & D.And once again I am excluding component which I dont want to show in D after created rep
so,Is there any option is available to maintain the same components which C rep has into D rep ?
Mahesh_Sharma
22-Sapphire I
Jun 25, 2014 5:51 PM UTC
Haris,
As you mentioned Rep D will be identical of C, to get this you can create rep D by copying rep C.
After creating C > Activate Master Rep > Select C > Edit Copy (or Right Click on C and Copy) Name as D (All in View manager).
Jun 26, 2014 2:26 AM UTC
Thank you so much
