Dec 16, 2016 4:23 PM UTC
How to Update License Server
I need to update my license server with the new license file so I can run Creo 4.0 but I can't figure out how.  I thought I could just go to the install file directory and run ptcsetup.bat and point it to the new license file, but I can't find the ptcsetup.bat file.  I tried searching the entire C: drive and didn't find it anywhere.  What am I missing or is there a different way to update the license file on the server?
Mike
3-Newcomer
Dec 16, 2016 4:59 PM UTC
Look for reconfigure.exe in the Creo bin directory.
Dec 16, 2016 5:57 PM UTC
On my computer I can find the reconfigure.exe file in the bin directory, but on the license server computer I can't find the reconfigure.exe file. I should have mentioned that we run our seats of Creo from a license server.
3-Newcomer
Dec 16, 2016 6:14 PM UTC
Here is another place to look:
C:\Program Files\PTC\FLEXnet Admin License Server\bin\reconfigure.lnk
This points to: "C:\Program Files\PTC\FLEXnet Admin License Server\InstallManager\reconfigure.exe" -xmlPath "C:\Program Files\PTC\FLEXnet Admin License Server/bin/pim/xml"
Dec 18, 2016 9:35 AM UTC
do you have FLEXnet license manager installed on your PC or on different one ?
MH
Dec 19, 2016 12:09 PM UTC
It is on a different computer.
Dec 19, 2016 12:19 PM UTC
I guess that FLEXnet manager installed on license server is represented by system service named lmadmin_ptc.
How to "install" new license file:
  • stop system service named lmadmin_ptc
  • go to C:\Program Files\PTC\FLEXnet Admin License Server\licensing directory
  • open license.dat file in Notepad
  • open new license file in Notepad
  • in license.dat file select two lines - SERVER and DAEMON - and copy the into clipboard using CTRL+C
  • in new license file replace SERVER and DAEMON lines with clipboard contents using CTRL+V
  • in new license file press CTRL+A to select whole contents of the file and copy the into clipboard using CTRL+C
  • in license.dat file press CTRL+A to select whole contents of the file and replace it with clipboard contents using CTRL+V
  • save and close license.dat file
  • do not save and close new license file
  • start system service named lmadmin_ptc
MH
