How to use "Desktop::ReadTextFromTrail" in OTK Java
Dear community,
does anybody know how to read from the trail file using Desktop.ReadTextFromTrail()?
/otk_java_doc/objecttoolkit_Creo/api/c-uifcDesktop-Desktop.html#ReadTextFromTrail
I cannot get a handle on desktop object.
Kind regards
Michael
uifc is part of paid version of java toolkit.
Can you describe what you are trying to achieve ?
MichelH1-VisitorAuthor
When I click a modelitem in the modeltree I get something like:
~ Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `node21`
which I wanted to use (`node21`) for building a mapkey dynamically...
You can programically prompt user to select model (eg. part or assembly) and toolkit return you handler to selected model object.
Selections sels = Session.Select(selOptions, null);
Model model = sels.get(0).GetSelModel();
String fileName = model.GetFileName();
