3-Newcomer
HowTo? TKapp#1 invoking TKapp#2
Creo10 & ProToolkit & Cpp...   Button#1 (in UI_dialog#1) would have a callback, which would... step1) load DLL#2, and then step2) Call an exported Function (eg. "display_dialog_2") which would result in UI_dialog#2 being displayed alongside-of, or in-front-of UI_dialog#1.   *But, I cant seem to get step 2 to work.  UI#2 never displays.  Any help&guidance would def be appreciated.  Code example(s) even better.
RPN
18-Opal
I,m not sure if this is a good idea😉
 But you may check this.
typedef ProError (*ProTkdllFunction)( ProArgument* inputs,
ProArgument** outputs );
Purpose: This is the function prototype for a function that can
be called from a external application using
ProToolkitTaskExecute().
Input Arguments:
inputs - ProArray of input arguments passed to the function.
The function must not free the array or any allocated
memory contained in this array.
Output Arguments:
outputs - ProArray of output arguments passed by the function.
The function must allocate memory for this array and
its contents.
Return Values:
Any return value - Passed as an output for ProToolkitTaskExecute().
See Also:
Emeritus
Hello @DeanK,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
