8-Gravel
IFX Drop-Down menu and error message when trying to assemble screw.
Our company upgraded to Creo 9 recently. I had custom IFX files that worked fine with Creo 7 and now having some issues in Creo 9.
First when select the drop-down for the screw catalog, the drop-down expands across the whole screen.
Second, when about to create/assemble screw I get an error message.
Here is the trail file.
!trail file version No. 2020
!Creo TM 9.0 (c) 2023 by PTC Inc. All Rights Reserved.
!Exit Logger data:
!	Process ID: 5448
!	Application: Creo_Parametric
!	Start date&time: 2023/11/18 16:20:49
!	language: usascii
!	machine type: x86e_win64
!	datecode: 9.0.4.0
!	Server: NONE
!	Workspace: NONE
!	traceback file: C:\work\guido.pedros\prodata\traceback.log
!end Exit Logger data.
< 0 0.964741 1528 0 0 814 1536 0 0 864 13
!mem_use INCREASE Blocks 1046364, AppSize 11539669, SysSize 33582072
< 0 1.052000 1052 0 0 1000 1536 0 0 864 13
< 0 1.055000 1055 0 0 1000 1536 0 0 864 13
< 0 1.055000 1055 0 0 1003 1536 0 0 864 13
< 0 1.055000 1055 0 0 1006 1536 0 0 864 13
< 0 0.929000 929 0 0 1006 1536 0 0 864 13
< 0 0.674370 1274 0 0 569 1536 0 0 864 13
< 0 0.674370 1232 0 0 569 1536 0 0 864 13
< 0 0.683852 1240 0 0 577 1536 0 0 864 13
!%CIWelcome to Creo Parametric 9.0.4.0.
< 0 0.655407 1240 0 0 553 1536 0 0 864 13
! Message Dialog: Question
! : The server is currently unavailable. Do you want to switch to offline mode?
~ Activate `UI Message Dialog` `no`
!%CIThe External File for Restricted Parameters has been read in. C:\Apps\creo9_stds\configs\keyword_params.lst.
~ Command `ProCmdModelOpen`
< 2 0.118519 178 0 0 100 1536 0 0 864 13
~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` \
 `file_open`
~ Select `file_open` `Ph_list.Filelist` 1 `t50108_location_block_assy.asm`
~ Activate `file_open` `Ph_list.Filelist` 1 `t50108_location_block_assy.asm`
!Command ProCmdModelOpenExe was pushed from the software.
!18-Nov-23 16:21:22 Start wtws://Windchill/Hardware/t50108_location_block_assy.asm|v=D.1
!LIGHT_FIX_MODEL_RMODE is 51
!18-Nov-23 16:21:22 Start wtws://Windchill/Hardware/t50108_locating_block.prt|v=D.1
!18-Nov-23 16:21:22 End wtws://Windchill/Hardware/t50108_locating_block.prt|v=D.1
!18-Nov-23 16:21:22 Start wtws://Windchill/Hardware/t50108_misumi_tpnv10-5_bushing<t50108_misumi_tpnv10-5tpnv10-5>.prt
!18-Nov-23 16:21:22 Start wtws://Windchill/Hardware/t50108_misumi_tpnv10-5tpnv10-5.prt|v=1.0
!18-Nov-23 16:21:22 End wtws://Windchill/Hardware/t50108_misumi_tpnv10-5tpnv10-5.prt|v=1.0
!%CIRegenerating T50108_MISUMI_TPNV10-5_BUSHING feature 6 out of 7 ...
!%CIRegenerating T50108_MISUMI_TPNV10-5_BUSHING feature 7 out of 7 ...
!%CIT50108_MISUMI_TPNV10-5_BUSHING regeneration completed successfully.
!18-Nov-23 16:21:40 End wtws://Windchill/Hardware/t50108_misumi_tpnv10-5_bushing<t50108_misumi_tpnv10-5tpnv10-5>.prt
!18-Nov-23 16:21:40 End wtws://Windchill/Hardware/t50108_location_block_assy.asm|v=D.1
@ oa_sel_filter_set _30_
!mem_use INCREASE Blocks 1346212, AppSize 55893574, SysSize 92159664
@ stack attr 2
!MT_CUST - Applied settings for mode # 6 : MT Asm Design
< 0 0.655407 1416 0 0 553 1536 0 0 864 13
< 0 0.679111 1240 0 0 573 1536 0 0 864 13
< 0 0.654222 1240 0 0 552 1536 0 0 864 13
< 0 0.625778 1240 0 0 528 1536 0 0 864 13
< 0 0.625778 1152 0 0 528 1536 0 0 864 13
! Message Dialog: Warning
! : The server to which this Workspace belongs is now available.
! : Please check for conflicts and out of date workspace data.
! : Checking for server complement of cached workspaces.
~ Activate `UI Message Dialog` `ok`
~ Wheel `main_dlg_cur` `proe_win` 9 485 256 393216 1024 1152 528 1536 864 60338
~ Wheel `main_dlg_cur` `proe_win` 9 505 246 393216 1024 1152 528 1536 864 60400
~ Wheel `main_dlg_cur` `proe_win` 9 545 228 393216 0 1152 528 1536 864 60460
~ Wheel `main_dlg_cur` `proe_win` 9 589 230 458752 0 1152 528 1536 864 60614
~ Wheel `main_dlg_cur` `proe_win` 9 589 230 458752 1024 1152 528 1536 864 60662
~ Wheel `main_dlg_cur` `proe_win` 9 589 230 458752 0 1152 528 1536 864 60732
~ Wheel `main_dlg_cur` `proe_win` 9 589 231 458752 1024 1152 528 1536 864 60828
~ Command `ifx_menu_screw_def_ex_pnt`
!%CIAssemble a screw fastener on an existing reference.
~ Select `screw_placement_dialog` `sel_point_axis_table` 0
!%CPSelect placement point/placement axis.
~ FocusIn `screw_placement_dialog` `sel_point_axis_table`
!playing mapkey $F3
~ Command `ProCmdEnvAxisDisp` 1
!%CIAxes will be displayed.
~ FocusOut `screw_placement_dialog` `sel_point_axis_table`
~ LButtonArm `main_dlg_cur` `proe_win` 9 321 247 0 1 1152 528 1536 864 68997
~ Move `main_dlg_cur` `proe_win` 9 321 247 0 1 1152 528 1536 864 69001
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 321 247 0 0 1152 528 1536 864 69045
@sel_pz_xyz 92.5071022727 449.0411931818 289.1224254261 471.2835138494 0.0000000000
@ sel view 0
 17.619933 193.406283 -153.361777 199.981311 78.938004 122.525727
 144.683448 -132.661556 -150.678129 211.190410 318.220760 -1484.519385 1.250000 0.000000 0
@ stack attr 8
@ stack attr -1 -1 1
@SEL_REC 1 [ 58] 4 2018 -1 (0.8421606674 0.0000000000) (-0.3244914136 0.6300000000 -0.3125000000)
!%CIShowing axis A_23 in model T50108_LOCATING_BLOCK.
!A_23(AXIS):F11(HOLE_2_2):T50108_LOCATING_BLOCK ID=2018
!%CPSelect screw head surface.
~ LButtonArm `main_dlg_cur` `proe_win` 9 377 230 0 1 1152 528 1536 864 70101
~ Move `main_dlg_cur` `proe_win` 9 377 231 0 1025 1152 528 1536 864 70106
~ Move `main_dlg_cur` `proe_win` 9 377 231 0 1 1152 528 1536 864 70114
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 377 231 0 0 1152 528 1536 864 70206
@sel_pz_xyz 181.9957386364 476.2073863636 360.7133345170 493.0164683949 0.0000000000
@ sel view 0
@ stack attr 8
@SEL_REC 1 [ 58] 2 378 -1 (0.4009701410 0.9165838025) (-0.3750000000 0.9165838025 -0.2240298590)
!%CIShowing surface created by feature 5 (EXTRUDE_1), model T50108_LOCATING_BLOCK.
!Surf:F5(EXTRUDE_1):T50108_LOCATING_BLOCK ID=378
!%CPSelect surface on the lower part (Thread/Nut).
~ LButtonArm `main_dlg_cur` `proe_win` 9 298 410 0 1 1152 528 1536 864 71201
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 298 410 0 0 1152 528 1536 864 71274
@sel_pz_xyz 55.7528409091 188.5653409091 259.7190163352 262.9028320312 0.0000000000
@ sel view 0
@ stack attr 8
~ RButtonArm `main_dlg_cur` `proe_win` 9 298 410 0 4 1152 528 1536 864 71682
~ RButtonDisarm `main_dlg_cur` `proe_win` 9 298 410 0 0 1152 528 1536 864 71798
!Popup menu item (Sel_query) was activated
~ LButtonArm `main_dlg_cur` `proe_win` 9 298 410 0 1 1152 528 1536 864 71916
~ Move `main_dlg_cur` `proe_win` 9 298 410 0 1 1152 528 1536 864 72032
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 298 410 0 0 1152 528 1536 864 72038
@ sel view 0
@ stack attr 8
!%CPShowing surface created by feature 5 (EXTRUDE_1), model T50108_LOCATING_BLOCK. Confirm selection.
!Surf:F5(EXTRUDE_1):T50108_LOCATING_BLOCK ID=382
~ MButtonArm `main_dlg_cur` `proe_win` 9 298 410 0 2 1152 528 1536 864 72740
~ Move `main_dlg_cur` `proe_win` 9 298 410 0 2 1152 528 1536 864 72750
~ MButtonDisarm `main_dlg_cur` `proe_win` 9 298 410 0 0 1152 528 1536 864 72870
** 0.055753 0.221591 0 4 4
0.259719 0.261624 M 0 0.625777778 0
@SEL_REC 1 [ 58] 2 382 -1 (0.1148997933 0.3875769072) (0.5000000000 0.3875769072 -0.1148997933)
!%CPSelect visible geometry item.
~ MButtonArm `main_dlg_cur` `proe_win` 9 298 410 0 2 1152 528 1536 864 73283
~ MButtonDisarm `main_dlg_cur` `proe_win` 9 298 410 0 0 1152 528 1536 864 73424
~ Activate `screw_placement_dialog` `ok_psh`
~ Open `screw_dialog` `screwtype_comboex`
~ Close `screw_dialog` `screwtype_comboex`
~ Select `screw_dialog` `screwtype_comboex` 1 `bhcs_inch`
~ Select `screw_dialog` `screwtype_comboex` 1 `fhcs_inch`
~ Select `screw_dialog` `screwtype_comboex` 1 `shss_inch`
~ Select `screw_dialog` `screwtype_comboex` 1 `setscrew_inch`
~ Select `screw_dialog` `screwtype_comboex` 1 `shcs_metric`
~ Select `screw_dialog` `screwtype_comboex` 1 `bhcs_metric`
~ Select `screw_dialog` `screwtype_comboex` 1 `fhcs_metric`
~ Select `screw_dialog` `screwtype_comboex` 1 `shss_metric`
~ Select `screw_dialog` `screwtype_comboex` 1 `setscrew_metric`
~ Select `screw_dialog` `screwtype_comboex` 1 `shcs_inch`
~ Trigger `screw_dialog` `screwtype_comboex` `shcs_inch`
~ Trigger `screw_dialog` `screwtype_comboex` `bhcs_inch`
~ Trigger `screw_dialog` `screwtype_comboex` `fhcs_inch`
~ Trigger `screw_dialog` `screwtype_comboex` `shss_inch`
~ Trigger `screw_dialog` `screwtype_comboex` `setscrew_inch`
~ FocusOut `screw_dialog` `screwtype_comboex`
~ Activate `screw_dialog` `nut_check` 1
~ Activate `screw_dialog` `nutspringwasher_check` 1
~ Activate `screw_dialog` `nutwasher_check` 1
~ Activate `screw_dialog` `screwwasher_check` 1
~ Activate `screw_dialog` `screwspringwasher_check` 1
~ Activate `screw_dialog` `screwspringwasher_check` 0
~ Activate `screw_dialog` `screwwasher_check` 0
~ Activate `screw_dialog` `nutwasher_check` 0
~ Activate `screw_dialog` `nutspringwasher_check` 0
~ Activate `screw_dialog` `nut_check` 0
~ FocusIn `screw_dialog` `screwdm_combo`
~ Open `screw_dialog` `screwdm_combo`
~ Trigger `screw_dialog` `screwdm_combo` `#3-48`
~ Trigger `screw_dialog` `screwdm_combo` `#3-56`
~ Trigger `screw_dialog` `screwdm_combo` `#4-40`
~ Trigger `screw_dialog` `screwdm_combo` `#8-32`
~ Trigger `screw_dialog` `screwdm_combo` `#8-36`
~ Trigger `screw_dialog` `screwdm_combo` `1/4-28`
~ Trigger `screw_dialog` `screwdm_combo` `5/16-18`
~ Trigger `screw_dialog` `screwdm_combo` `5/16-24`
~ Trigger `screw_dialog` `screwdm_combo` `3/8-16`
~ Trigger `screw_dialog` `screwdm_combo` `3/8-24`
~ Close `screw_dialog` `screwdm_combo`
~ Select `screw_dialog` `screwdm_combo` 1 `3/8-24`
~ Activate `screw_dialog` `screwautolength_button`
~ Activate `screw_dialog` `pb_OK`
!%CE'SET_SCREW-3_8-24x0_875' cannot be retrieved.
!18-Nov-23 16:23:12 Start C:\Apps\PTC\Creo 9.0.4.0\Common Files\ifx\parts\ifx_fastener_data\setscrew_inch.prt.1
!sket_eps 0.0121231877
!18-Nov-23 16:23:12 End C:\Apps\PTC\Creo 9.0.4.0\Common Files\ifx\parts\ifx_fastener_data\setscrew_inch.prt.1
!Undo: added rec_id 322 type 5204
!Undo: added rec_id 326 type 5204
!Undo: added rec_id 328 type 5204
!Undo: added rec_id 330 type 5204
!Undo: added rec_id 333 type 5204
!%CDLine 6 part SETSCREW_INCH: Invalid symbol 'BUW_NAME' found.
!%CDLine 7 part SETSCREW_INCH: Invalid symbol 'BUW_TYPE' found.
!%CDRelations have errors/warnings. Refer to the message log for the details or visit relation UI.
! Message Dialog: Error
! : An unhandled exception occurred.
! : Please report this error along with the trail file and a screenshot of this message.
! : Diagnostic information:
! : utilitiy.cpp(4098): Throw in function utility::AddRelationsToRelset
! : Dynamic exception type: struct buw::toolkit_error
! : std::exception::what: Unknown exception
! : [struct buw::tag_error_msg * __ptr64] = Toolkit error (PRO_TK_GENERAL_ERROR)
! : [struct buw::tag_tk_error * __ptr64] = -1
~ Close `UI Message Dialog` `UI Message Dialog`
!ProgressBarDlg: Regen Started
!%CIRegenerating SETSCREW_INCH feature 1 out of 6 ...
!%CIRegenerating SETSCREW_INCH feature 2 out of 6 ...
!%CIRegenerating SETSCREW_INCH feature 3 out of 6 ...
!%CIRegenerating SETSCREW_INCH feature 4 out of 6 ...
!%CIRegenerating SETSCREW_INCH feature 5 out of 6 ...
!%CIRegenerating SETSCREW_INCH feature 6 out of 6 ...
!%CISETSCREW_INCH regeneration completed successfully.
!ProgressBarDlg: Regen Completed
!%CWWARNING: Some constraint relations are no longer satisfied in SETSCREW_INCH.PRT.
!18-Nov-23 16:24:19 Start wtws://Windchill/Hardware/set_screw-3_8-24x0_875.prt
!18-Nov-23 16:24:19 End wtws://Windchill/Hardware/set_screw-3_8-24x0_875.prt
!%CISET_SCREW-3_8-24X0_875 has been saved.
~ Activate `sel_multiref_dialog` `pb_Cancel`
~ Trigger `screw_placement_dialog` `sel_point_axis_table` 2 `row_1` `column_1`
~ Trigger `screw_placement_dialog` `sel_point_axis_table` 2 `` ``
~ LButtonArm `main_dlg_cur` `proe_win` 9 322 243 0 1 1152 528 1536 864 219887
~ Move `main_dlg_cur` `proe_win` 9 322 243 0 1 1152 528 1536 864 219897
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 322 243 0 0 1152 528 1536 864 219953
@sel_pz_xyz 94.1051136364 455.4332386364 290.4008345170 476.3971502131 0.0000000000
@ sel view 0
@ stack attr 8
@SEL_REC 1 [ 58] 4 2018 -1 (0.9231997283 0.0000000000) (-0.3504239131 0.6300000000 -0.3125000000)
~ LButtonArm `main_dlg_cur` `proe_win` 9 371 227 0 1 1152 528 1536 864 220447
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 371 227 0 0 1152 528 1536 864 220519
@sel_pz_xyz 172.4076704545 481.0014204545 353.0428799716 496.8516956676 0.0000000000
@ sel view 0
@ stack attr 8
@SEL_REC 1 [ 58] 2 378 -1 (0.3633410190 0.9067620662) (-0.3750000000 0.9067620662 -0.2616589810)
~ RButtonArm `main_dlg_cur` `proe_win` 9 322 399 0 4 1152 528 1536 864 220847
~ Move `main_dlg_cur` `proe_win` 9 322 399 0 4 1152 528 1536 864 220848
~ Move `main_dlg_cur` `proe_win` 9 322 400 0 1028 1152 528 1536 864 220852
~ Move `main_dlg_cur` `proe_win` 9 321 401 0 1540 1152 528 1536 864 220860
~ Move `main_dlg_cur` `proe_win` 9 321 402 0 1028 1152 528 1536 864 220872
~ Move `main_dlg_cur` `proe_win` 9 321 403 0 1028 1152 528 1536 864 220880
~ Move `main_dlg_cur` `proe_win` 9 320 404 0 1540 1152 528 1536 864 220892
~ Move `main_dlg_cur` `proe_win` 9 320 405 0 1028 1152 528 1536 864 220904
~ Move `main_dlg_cur` `proe_win` 9 319 406 0 1540 1152 528 1536 864 220912
~ Move `main_dlg_cur` `proe_win` 9 319 407 0 1028 1152 528 1536 864 220920
~ Move `main_dlg_cur` `proe_win` 9 318 407 0 516 1152 528 1536 864 220922
~ Move `main_dlg_cur` `proe_win` 9 318 408 0 1028 1152 528 1536 864 220926
~ Move `main_dlg_cur` `proe_win` 9 318 409 0 1028 1152 528 1536 864 220930
~ Move `main_dlg_cur` `proe_win` 9 317 410 0 1540 1152 528 1536 864 220938
~ Move `main_dlg_cur` `proe_win` 9 317 411 0 1028 1152 528 1536 864 220946
~ Move `main_dlg_cur` `proe_win` 9 317 412 0 1028 1152 528 1536 864 220950
~ Move `main_dlg_cur` `proe_win` 9 317 413 0 1028 1152 528 1536 864 220954
~ Move `main_dlg_cur` `proe_win` 9 316 414 0 1540 1152 528 1536 864 220962
~ RButtonDisarm `main_dlg_cur` `proe_win` 9 316 414 0 0 1152 528 1536 864 220963
~ LButtonArm `main_dlg_cur` `proe_win` 9 295 404 0 1 1152 528 1536 864 221297
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 295 404 0 0 1152 528 1536 864 221391
@sel_pz_xyz 50.9588068182 198.1534090909 255.8837890625 270.5732865767 0.0000000000
@ sel view 0
@ stack attr 8
~ RButtonArm `main_dlg_cur` `proe_win` 9 296 404 0 4 1152 528 1536 864 221504
~ Move `main_dlg_cur` `proe_win` 9 296 404 0 4 1152 528 1536 864 221512
~ RButtonDisarm `main_dlg_cur` `proe_win` 9 296 404 0 0 1152 528 1536 864 221585
~ MButtonArm `main_dlg_cur` `proe_win` 9 303 423 0 2 1152 528 1536 864 222014
~ MButtonDisarm `main_dlg_cur` `proe_win` 9 303 423 0 0 1152 528 1536 864 222079
** 0.063743 0.196970 0 4 4
0.266111 0.245005 M 0 0.625777778 0
@SEL_REC 1 [ 58] 2 382 -1 (0.1647906802 0.4073080542) (0.5000000000 0.4073080542 -0.1647906802)
~ MButtonArm `main_dlg_cur` `proe_win` 9 767 95 0 2 1152 528 1536 864 223347
~ Move `main_dlg_cur` `proe_win` 9 767 96 0 1026 1152 528 1536 864 223347
~ Move `main_dlg_cur` `proe_win` 9 767 96 0 2 1152 528 1536 864 223358
~ MButtonDisarm `main_dlg_cur` `proe_win` 9 767 96 0 0 1152 528 1536 864 223451
~ Trigger `screw_dialog` `screwtype_comboex` `shcs_metric`
~ Trigger `screw_dialog` `screwtype_comboex` `bhcs_metric`
~ Trigger `screw_dialog` `screwtype_comboex` `fhcs_metric`
~ Trigger `screw_dialog` `screwtype_comboex` `shss_metric`
~ Trigger `screw_dialog` `screwtype_comboex` `setscrew_metric`
~ FocusIn `screw_dialog` `screwtype_comboex`
~ Activate `screw_dialog` `pb_Cancel`
!%CEAction aborted by user.
~ LButtonArm `main_dlg_cur` `proe_win` 9 834 421 0 1 1152 528 1536 864 310161
~ Move `main_dlg_cur` `proe_win` 9 833 421 0 513 1152 528 1536 864 310166
~ Move `main_dlg_cur` `proe_win` 9 832 421 0 513 1152 528 1536 864 310174
~ Move `main_dlg_cur` `proe_win` 9 831 421 0 513 1152 528 1536 864 310182
~ Move `main_dlg_cur` `proe_win` 9 830 421 0 513 1152 528 1536 864 310194
~ Move `main_dlg_cur` `proe_win` 9 829 421 0 513 1152 528 1536 864 310204
~ Move `main_dlg_cur` `proe_win` 9 828 421 0 513 1152 528 1536 864 310210
~ Move `main_dlg_cur` `proe_win` 9 827 421 0 513 1152 528 1536 864 310222
~ Move `main_dlg_cur` `proe_win` 9 826 421 0 513 1152 528 1536 864 310230
~ Move `main_dlg_cur` `proe_win` 9 825 420 0 1537 1152 528 1536 864 310246
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 825 420 0 0 1152 528 1536 864 310255
@ sel view 0
~ LButtonArm `main_dlg_cur` `proe_win` 9 1005 132 0 1 1152 528 1536 864 365708
~ Move `main_dlg_cur` `proe_win` 9 1005 132 0 1 1152 528 1536 864 365711
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 1005 132 0 0 1152 528 1536 864 365774
@sel_pz_xyz 1185.5468750000 632.8125000000 1163.5542436080 618.3005593040 0.0000000000
@ sel view 0
@ stack attr 8
~ Close `main_dlg_cur` `main_dlg_cur`
!Command ProCmdOSExit was pushed from the software.
! : Creo Parametric will terminate and any unsaved work will be lost.
! : Do you really want to exit?
~ Activate `UI Message Dialog` `yes`
!End of Trail File
OliverGräbner
in IFX 9 we add a verification check of the relations after setting them.
The error might also occure in Creo 7.0 but there only no message was shown.
You can either change your *.dat file and add the missing BUW_NAME and BUW_TYPE and BUW_SIZE or you can change the param_releation.txt to you needs.
Relation Files (ptc.com)
Regarding the other problem with the tabs.
You already have found the error by yourself.
You can use one or two tabs in the INFO value if you want to align some values in a extra column in you drop down.
But if you have too many tabs this might lead into display problems.
So I think this topic can be marked as solved.
Oliver Gräbner - B&W Software GmbH
gpedros8-GravelAuthor
8-Gravel
Ok, I figured out the drop-down window issue. I had too many tabs after the INFO description.
The error I'm getting I believe is when I select the screw I want and then click OK, when Creo creates that instance it adds 2 relations which my models don't even have.
Emeritus
Hello gpedros,
Thank you for using PTC Community!
PTC Community cannot help you with any issues related to "Traceback log error". For such issues, you could open a support case on the eSupport portal if:
1) You have an active global support agreement(maintenance) and a SCN (service contract number)
2) You are on a Supported release & date-code of the product as per the PTC Product calendar.
Please create a case and our Technical Support Engineer will be happy to help you.
Hope this helps.
Vivek N
Community Moderation Team.
