Importing files with assembly level appearance
Hi.
Creo 7 here.
I'm trying to find a way to modify import recipe or whatever else could be driving this in order to have Creo import assemblies which contain assembly level appearance modifications with those modifications.
Here's the issue breakdown:
I have assemblies which mostly contain frames designed in Inventor/Solidworks. I export them to STEPs and import into Creo (cause I need to output PVZ files in the end). Parts which have appearance overrides are being imported with those overrides but any override at assembly level (no matter the depth) is not being imported.
Now, I tried both 214 and 242 export protocols, I tried every option available in import settings and nothing gives me the result. I know those appearances are present in exports cause I can import them again into other software and they're there.
Fun fact is, that the first time I did all of this Creo imported everything as intended...I think I may have altered something in Creo and now it's upset.
I'll be grateful for help.
Kind regards,
Tom
I'm faced several problems with a color for import step files.
I think, you can try to use another file format (IGES, sat).
If you exporting from Creo, then try *.neu file format.
My apologies, for whatever reason I didn't see the original post at first.
So my reply is for a question not asked.
I can't delete my reply so I'll leave it here.
It all depends on what STEP format you are using.
I'll consider two scenarios, namely model export using Creo and model export using another CAD system.
I've created a short video to show you this.
You can use STEP AP203e2, STEP AP214 and STEP AP242 to preserve colours.
I would advise to use STEP AP214 as this is probably the best supported "colour" STEP amongst different CAD/CAM systems.
please read https://www.ptc.com/en/support/article/cs22317 document.
I have done some testing here and I encounter the same problems as you.
When I change the appearance of a part within Inventor 2022 and import that into Creo 8.0.3.0 or FreeCAD 0.19 the colours are not retained. As it works for parts, I suspect there is a setting within Inventor that must be set. I'll be doing some additional testing.
I have done additional testing with Creo 8.0.3.0, FreeCAD 0.19, Siemens NX.
I can't retain the colours in these three systems when assigning an appearance in Inventor to a part within an assembly and then export the assembly to STEP AP214.
It is indeed so that when I import the STEP file back into Inventor the colours are retained.
This convinces me that there must be something that is unique to Inventor.
Thank all of you for participating in the debate.
JB, awesome reply. Thanks.
I'm on Inventor 2021 btw. Honestly I am 100% sure I did get the colour retention the first time...sadly I deleted the step and all I'm left with is an .ol file that I think I can export from Creo Illustrate standard. Not gonna help much though. I'll try tomorrow with solidworks. And yes, importing steps back into Inventor results with colours being there...
