In Creo 5 ExecuteFeatureOps fails with an exception XToolkitBadContext
I'm on Creo Parametric 5
and aware that starting from Creo 7, ExecuteFeatureOps() does not work anymore.
It shows a feature count of 2 in CpfcFeatureOperations but the following fails:
solid1.ExecuteFeatureOps(suppressOp, regen.Create(False, False, Nothing))
I think the instrs object in the second argument is the culprit.
What could possibly be wrong in this argument?
Any help is highly appreciated.
sjurajAnswer
feature operations is available only in paid version of jlink (wfc package) .. there is no workaround .. so if you want to use free jlink you can only use macros
Thank you @sjuraj for the redirection.
Unfortunately, the support articles in that post are off-limit for a basic user.
So the problem remains unsolved.
I'd appreciate it if I get any directions toward solving the issue.
sjuraj15-MoonstoneAnswer
