Insert drawing note at specific location
Similar to this thread:
Did you figure out how to do this?
I am working on similar requirement,
Please let me know if you have figured it out.
Prasad
You need assistance in inserting a drawing note at a specific location. Can you offer more details on that specific location. Do you mean a coordinate based location ?
Drawing note can be inserted in various manners by default ? What a particular reasons these options don't addresses your expectations?
Prasad_G12-AmethystAuthor
Hi Remy,
Thanks for your reply
I want to enter notes at particular X and Y coods of drawing.
I tried to use the logic from examples (placed in "vbapi" folder of CREO) but the notes get placed at random location.
Prasad
Your reply enables me to understand that:
  • you need to create a Drawing note
  • the inputs are X and Y coordinate
  • your project is VB bound
Being more a Creo Toolkit (C) than a VB specialist, my answer will be Toolkit based and i'll let you do the refactoring.
One article you can look into is the following : https://www.ptc.com/en/support/article/cs238197 it will help you understand how to create a note.
A second article will be of interest to you : https://www.ptc.com/en/support/article/cs205214 it will help you understand the window coordinate management.
More about screen coordinate here: https://www.ptc.com/en/support/article/cs250163 the VB code enables to place a table to specific coordinate
and also this one : https://www.ptc.com/en/support/article/cs300096
Tell me if any of the articles was helpful.
