3-Newcomer
May 14, 2024 2:01 PM UTC
Installing Creo 8 using Jlink- JRE 11.0
I'm looking for some documentation on how to install Creo 8 with Corretto (JRE 11 ).  I've searched the PTC website but I'm not finding it.  I'm looking for installaing a new setup, as well as converting an existing setup to not use Java, and use Corretto ( JRE 11 ).  If you can point me to a document I'll be happy to read and try it out.
Anyone able to help point me in the right direction.
Any help would be greatly appreciated.
Thanks.
20-Turquoise
May 14, 2024 9:46 PM UTC
Download the Amazon corretto 11 zip for Windows x64:
https://corretto.aws/downloads/latest/amazon-corretto-11-x64-windows-jdk.zip
Unzip this and set PRO_JAVA_COMMAND to the <unzipped_folder\bin\java
In my case I unzip, rename the unzipped folder to java and move it to my Creo Parametric install directory:
c:/ptc/creo_parametric-8.0/java
And then set PRO_JAVA_COMMAND = c:\ptc\creo_parametric-8.0\java\bin\java
20-Turquoise
