Intelligent Fastener folder
Hi all,
I would like to know if exist a parameter to set up for not create a fastener file everytime I add a fastner into a assembly.
If I insert a new fastner using IFX, I will have  a prt file inside the folder of my project. Is it possible to save all the fastnere that I will use in every assembly in a single folder so is not necessary to re-crate a new file everytime I will insert that fastner in another assembly?
OliverGräbner
if you do not have a file management system like Windchill, you can use a search path in Creo where you can store existing files like fasteners and so on.
You find several help files for this in the Help Center.
Here e.g. is an example.
Example: Adding Search Paths (ptc.com)
IFX support such mechanism.
Set the IFX option 'USE_ARCHIVES' to 'YES' and set the IFX option 'PATH_ABS_ARCHIVES' to an existing folder.
General Configuration Options (ptc.com)
Also set a Creo option 'search_path' to this folder.
If you now create new parts with IFX they will automatically be created in the 'PATH_ABS_ARCHIVES' folder.
And if the Creo Option 'search_path' ist set, they will be reused later on if you assemble the same fastener.
If you want to create more than one instance, you can use the IFX 'Instance Creator' to create all instances from one *.dat file.
To Create Library Components (ptc.com)
Oliver Gräbner - B&W Software GmbH
OliverGräbner
Fortech5-Regular MemberAuthor
Thanks a lot  for your support, it's exactly what I was looking for
