Nov 20, 2025 12:06 PM UTC
Intelligent fastner and personal order code
Good afternoon i'm using Creo parametric 11 with the intelligent fastner lite version.
I would like to know if it possibile to modify or add some screw starting from the template for have my personal codification.
Thank you for your time and help.
OliverGräbner
Nov 21, 2025 7:57 AM UTC
You can customize the existing parameter values by changing them inside the *.dat (Fastener Data Files) file.
If your fastener already exist it will not be modified. Existing fasteners will always be reused if possible.
The modified parameters will only affect newly created fasteners.
See also:
Fastener Data Files
About Customizing the Fastener Library
To Modify Fasteners
Oliver Gräbner - B&W Software GmbH
OliverGräbner
Nov 20, 2025 1:29 PM UTC
customizing fasteners is not supported for the lite version.
We only allow a set of parameter names:
Allowable Model Parameters
In addition the dat files cannot be modified. It is not possible to change the names of your fasteners.
The full version of IFX is now included inside the Creo Design packages.
Creo Packages | PTC Products
Nov 21, 2025 7:52 AM UTC
Thank you so much for the clarification, i have to set the parameter every time that i open a fastner or it's possibile to change the parameter once ?
OliverGräbner
See also:
Fastener Data Files
To Modify Fasteners
