Dec 5, 2019 4:07 PM UTC
Is a full Java Object-Toolkit installation needed on a client machine?
Dear community,
I wrote a OTK-Java-free application which runs fine on my developing environment. I am having problems to get the app working on client machines though.
One basic question: Is it possible to run this java-app without Java Object-Toolkit installation on the client machine? If so, how do I link to otk.jar?
I tried to link to the manually copied jar file in severals ways without success:
via config.pro option: jlink_java_command [path-to-folder]\java.exe -cp [path-to-folder]\otk.jar
via creotk.dat option: JAVA_APP_CLASSPATH [path-to-folder]\MyApp.jar;[path-to-folder]\otk.jar
I appreciate your help!
Best regards
Michael
Dec 6, 2019 8:15 AM UTC
you can test my uploaded example.
Once you unzip file, you have to modify protk.dat and Creo 5.0.2.0.bat.
Note: D:\Java\jdk64\jre\bin\java.exe ... java version "1.8.0_231"
MichelH1-VisitorAuthor
Dec 6, 2019 11:46 AM UTC
Hello Martin,
thank you very much for your answer!
I did not test your example but I see how you link to otk.jar: by setting the classpath variable in the startup batch file. This should work, I believe! But I want to avoid altering the startup precedure on the client machines.
This is why I am trying to change the classpath either in the config.pro or the creotk.dat. I also tried a third option: linking to otk.jar inside my jar file via MANIFEST.MF
I just managed to get it running with setting the config.pro option to
jlink_java_command [path]\java.exe -cp [path]\otk.jar
This is second best, because inside config.pro I only want to link to the creotk.dat, e. g.
toolkit_registry_file [path]\creotk.dat
(I want to avoid that the user has to deal with internals like java classpaths).
So the best thing would be to set the classpath either in creotk.dat or the MANIFEST.MF file of my jar application.
Do you have any idea how to do so?
Best regards
Michael
Dec 6, 2019 12:56 PM UTC
@MichelH wrote:
Hello Martin,
Best regards
Michael
I asked Google ... protk.dat java_app_classpath site:ptc.com
In result list I found https://community.ptc.com/t5/Customization/JLink-adding-external-libraries-to-classpath/td-p/374767 discussion. It contains following information:
in the meantime I figured a rather strange looking syntax for the protk.dat by dividing two libs with a ".;"
java_app_classpath /apps/lib1.jar.;./apps/lib2.jar
So I removed CLASSPATH definition from Creo 5.0.2.0.bat and modified protk.dat (see attachment):
java_app_classpath D:\users\mh\creo5_parametric\PTC_JLink\install_test_05.;.E:\PTC\Creo5_020\Creo 5.0.2.0\Common Files\text\java\otk.jar
