Aug 11, 2026 6:04 AM UTC
Is there an API to inject raw triangle mesh data into a Creo part, or must we use file-based STL/3MF import or build BREP via ProIntfData?
Hello Creo API team,
We are building a Creo Plugin . We already have tessellation data in memory:
  • Vertex coordinates (x, y, z)
  • Triangle connectivity (facet index list)
  • Optional normals
Can we create faceted/mesh geometry in a Creo part from this data programmatically (no UI)?
Specifically: Is there a public ProToolkit API to create mesh geometry directly from in-memory vertex + triangle buffers (similar to passing a vertex buffer and index buffer)?
If not, what is the recommended approach
Environment: Creo 11.x, ProToolkit C++, Windows x64.
Thank you.
Catalina
Community Manager
Aug 21, 2026 3:22 PM UTC
Hi ​@VM_14590081
Thank you for your question. 
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Catalina | PTC Community Manager
