Dec 19, 2025 6:03 AM UTC
Issue with ProUIDialogCreate Returning PRO_TK_GENERAL_ERROR
Hello guys,
I am facing an issue with the ProUIDialogCreate API returning PRO_TK_GENERAL_ERROR when a dialog creation DLL is invoked from another DLL. When the same DLL is executed independently, ProUIDialogCreate returns PRO_TK_NO_ERROR and the dialog is created successfully.
Note: The ProUIDialogCreate call is implemented inside the user_initialize() function.
if anyone knows the solution, pls let me know.
regards
Araivnd
Dec 22, 2025 1:42 PM UTC
Hello @Navku @MartinHanak guys
I really appreciate your response actually, it was my mistake I'd given the wrong text dir path. Now the tool is working as expected.
Regards
Aravind
Dec 19, 2025 10:09 AM UTC
please contact PTC Support, too.
Dec 22, 2025 1:33 PM UTC
Keep filename and dialog name inside the res file as same.
If you rename the res file, It will create error.
Aravind_9810-MarbleAuthorAnswer
Regards
Aravind
