Sep 10, 2010 3:14 PM UTC
J-Link and editing a pattern table.
I would like to confirm that this is possible.
I have a pattern of datum points (defined as offsets from a spherical coordinate system). The pattern is in a table.
Is it possible using J-Link to edit this pattern table? Change coordinates as well as add pattern members with new values?
FYI, I will be reading these values from a text file located on our network...
Has anyone done this or similar and would you be willing to share your code?
Sep 10, 2010 9:12 PM UTC
I think that this possible with Toolkit only and not with one of the PFC
APIs like Weblink, VB and Jlink.
Perhaps it is possible to write a mapkey that is able to re-read your
external file. But I think there is no method in Jlink that?s able to edit a
pattern table to change values or add/remove members.
Andreas
Sep 13, 2010 5:39 AM UTC
It is possible to edit dimension value through J-Link, so you can edit
existing points in the pattern. But you will not be able to add new
points.
I have a J-Link utility that reads in a point pattern table by creating
the .pts file and then ends with defining a macro that will read in the
file after the utility has ended.
Bjarne
Michael Gamber <->
10-09-2010 17:14
Please respond to
Michael Gamber <->
To
cc
Subject
[proecus] - J-Link and editing a pattern table.
network...
code?
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
Oct 13, 2010 3:20 PM UTC
It is not possible to edit the patter table directly but you can import a point file and change the dimensions.
