J-Link_Creo 5_external_applications
Hello!
Please tell me how I can run external applications from Creo using J-Link (for example, a Windows calculator). I already created a button in the taskbar, now I want to assign it such functionality.
Best Regards!
18-Opal
18-Opal
That should be a straight up Java thing:
https://javaconceptoftheday.com/how-to-launch-external-applications-through-java-program/
Dave
VladiSlav17-PeridotAuthor
Thanks for the answer!
This I understood how to do, the code works.
But I need to open a website or application using a button from Creo. For this, I think that the created class object should be in the application session.
I don’t know how to add it there. If I'm on the right track at all..
Best Regards!
I think this is two separate task:
1) to open a website pfcWindow.Window.SetURL
2) Creo macros can call external application. From J-Link you can a macros
pfcSession.BaseSession.RunMacro
wfcWSession.WSession.ExecuteMacro
