Aug 23, 2019 5:09 AM UTC
Java version for Jlink
I am currently using Creo elements/pro 5.0, I want to know which java version has to be used for Jlink application.
Regards
Gopichand RB
Aug 23, 2019 8:55 AM UTC
Regards
Gopichand RB
my suggestion:
  1. check Jlink component during Creo elements/pro 5.0 installation
  2. find java.exe in Creo installation
  3. run java.exe -version to get Java JRE version
  4. use the same JDK to compile your Jlink code
Gopichand1-VisitorAuthor
Aug 23, 2019 9:33 AM UTC
Hi Martin
In one of your previous answer you suggested the following link for java version to be used for compiling the java files, shall I use the java 1.4.1 SDK and JRE for compile the java file.
https://community.ptc.com/sejnu66972/attachments/sejnu66972/customization/2514/1/J-LinkCreoParametri... link
Regards
Gopichand RB
Aug 23, 2019 9:57 AM UTC
@Gopichand wrote:
Hi Martin
Regards
Gopichand RB
mentioned PDF file is related to Creo Parametric 2.0. I do not know how to get document related to Creo Elements/Pro 5.0.
