Jun 28, 2019 12:00 PM UTC
jlink: 3D import gets wrong file extensions and import in one monolithic part
- 1 reply
- 1239 views
- Translate All
I converted an 3D Assembly to the neutral format IGES (see STOSSDAEMPFER.igs in folder input).
An then I want to convert this file to a Pro/E model with CREO3 jlink.
Here my code:
Model model = session.ImportNewModel("C:\\my_path\\STOSSDAEMPFER.igs", NewModelImportType.IMPORT_NEW_IGES, ModelType.MDL_ASSEMBLY, "STOSSDAEMPFER", null);
model.Save();
Here my code:
model.Save();
The result of this conversion is in folder output.
Now I have following questions:
1. The Assembly and Sub-Assembly files (stossdaempfer.prt.1, stossdaempfer_daempfer.prt.1, stossdaempfer_gehaeuse.prt.1, stossdaempfer_motor.prt.1 and stossdaempfer_schwimmlager.prt.1) have the file extensions .prt instead of .asm. When I open one of my Assembly files in Pro/E GUI I get the error message e.g. "'STOSSDEAMPFER' cannot be retrievied". When I change the file extensions .prt to .asm of my Assembly files I can I open the Assembly files in Pro/E GUI.
What is the reason of the wrong file extensions .prt of my Assembly files?
2. Can I configure that only one monolithic part is created?
Thank's for your hints, Thomas
