Mar 9, 2010 8:00 PM UTC
JLink adding external libraries to classpath
Hi guys,
I try to use .jar files within my jlink application.
What I did is to add those to the java_app_classpath within the protk.dat file.
eg.
java_app_classpath ./apps/Library.jar; ./apps/classes
java_app_classpath ./apps/Library.jar ./apps/classes
but neither did work, as soon as I'm calling a class within the .jar a ClassNotFoundException is thrown.
Would be really glad if anybody knows how to handle this.
Regards
Mar 10, 2010 7:08 AM UTC
Hi Paul,
you can add jar files by using the config.pro option add_java_class_path.
Use the option once for each jar library like:
add_java_class_path <full path=">\xxx.jar
add_java_class_path <full path=">\yyy.jar
Bjarne
Paul Benoe <diesunddas2@web.de>
09-03-2010 21:59
Please respond to
To
cc
Subject
[proecus] - JLink adding external libraries to classpath
Hi guys,
file.
eg.
Regards
Site Links: View post online View mailing list online Send new post
via email Manage your subscription Use of this email content is
governed by the terms of service at:
Mar 10, 2010 12:01 PM UTC
thanks, that's good if you have multiple auxiliary applications using the same libraries.
in the meantime I figured a rather strange looking syntax for the protk.dat by dividing two libs with a ".;"
java_app_classpath /apps/lib1.jar.;./apps/lib2.jar
Thanks again,
Regards
Mar 16, 2010 5:39 PM UTC
Hello Paul
Add the additional jar files at the end or your java_app_classpath using semi colons in your protk.dat file as shown below.
java_app_classpath C:\project\jar\appJar.jar;C:\foldername\lib.jar;C:\folderName\lib2.jar
In Reply to Paul Benoe:
Hi guys,
eg.
Regards
