Dec 7, 2010 4:26 PM UTC
jlink - help with creating a free note
I'm hoping the JLink gurus out there can help me with placing a non-attached
drawing note.
I found an example in the documentation, but it uses a Point3d for the
placement, and I cant' figure out how a Point3d coordinates correspond to
drawing boundaries. Can anyone help me out with this? Either that or point
me to a method of note creation that uses something other than Point3d for
placement?
Thanks!
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Dec 13, 2010 8:46 AM UTC
Lyle.
You will have to use the tranformation matrix for the sheet by using
GetSheetTransform.
Use the inverted transformation matrix to go from sheet coordinates to
screen coordinates, which are generally used by J-link methods.
You can read more in theJ-Link API Wizard section: Windows and Views >
Coordinate Systems and Transformations.
/Bjarne
Lyle Beidler <->
07-12-2010 16:27
Please respond to
Lyle Beidler <->
To
cc
Subject
[proecus] - jlink - help with creating a free note
I’m hoping the JLink gurus out there can help me with placing a
non-attached drawing note.
placement, and I cant’ figure out how a Point3d coordinates correspond to
point me to a method of note creation that uses something other than
Point3d for placement?
Thanks!
Lyle Beidler
MGS Inc
Denver PA 17517
717-336-7528
Fax 717-336-0514
