8-Gravel
Mar 29, 2021 10:49 AM UTC
JLink in Creo 7.0.3.0
I have an async JLink application that has been running OK for many years.
Now I am testing it with Creo 7 and any 'ExecuteFeatureOps' fail with 'XToolkitBadContext'.
I have tried the new RegenInstructions option 'SetResolveModeRegen(true)' but it still throws the error.
Has anybody any ideas?
20-Turquoise
Mar 29, 2021 2:48 PM UTC
You will need to open a case with PTC tech support to get a "magic number" to use with the allow_deprecated_config config option. Once you have this you can then use the regen_failure_handling config option, which is still needed, when using jlink ExecuteFeatureOps.
You will have to get an updated "magic number" when you start using Creo Parametric 8 because this number changes with releases.
See article  CS260154: https://www.ptc.com/en/support/article/CS260154
PTC apparently did not think this change thru.
Mar 29, 2021 5:45 PM UTC
CS323992 contains following information ... Creo Parametric 7.0.2.0 onwards, to use the resolve mode, set pfcSolid.RegenInstructions.SetResolveModeRegen(true) and pass that RegenInstructions object to pfcSolid.Solid.Regenerate().
If you use this procedure and it does not work, then prepare testing application and send it to PTC Support.
Mar 29, 2021 5:51 PM UTC
Also read  CS323327.
