Jun 2, 2011 4:23 PM UTC
Jlink Insert Feature sample in UG
The following code, that is in the Wildfire 4.0 toolkit documentation, always produces the XToolkitNotFound exception. Can anyone tell me if there is something special that I need to know to get this code to work?
public Feature createImportFeatureFromDataFile (Solid solid, String csys, String filename) throws Exception
IntfNeutralFile data_source;
ModelItems c_systems;
CoordSystem c_system = null;
Feature import_feature = null;
ImportFeatAttr feat_attr;
try
data_source = pfcModel.IntfNeutralFile_Create(filename);
c_systems = solid.ListItems(ModelItemType.ITEM_COORD_SYS);
for (int i = 0; i < c_systems.getarraysize(); i++)
if (c_systems.get(i).GetName().equals(csys))
c_system = (CoordSystem)c_systems.get(i);
break;
feat_attr = pfcModel.ImportFeatAttr_Create();
feat_attr.SetJoinSurfs(true);
feat_attr.SetMakeSolid(true);
feat_attr.SetOperation(OperationType.ADD_OPERATION);
feat_attr = null;
import_feature = solid.CreateImportFeat(data_source,
c_system,
feat_attr);
catch (jxthrowable x)
System.out.println("Exception Occured:" + x);
throw new Exception(x);
etc...etc...etc...
Paul
Jun 3, 2011 1:32 PM UTC
The actual code is on page 22-43 of the Wildfire 5.0 JLink Users Guide.
Jun 20, 2011 3:42 PM UTC
Well....that was truely painful to figure out - by slow process of elimination. File has to be in the WD folder, and has to be versioned.
Question 2: How do you get session.CreatePart to use the template? (an act of purest optimism to oppose the question in the first place....)
