jLink Java application startup failed - Creo 7 + JDK 11
We have 3 jLink (java) applications/plugins correctly running on PTC Creo 7 + Java 8. Now we're testing Creo 7 + Java 11 (because of future upgrade to Creo 9/10 with Java 11). We've compiled plugins files with a same JDK11 but one of the plugins fails running with message 'Startup of application "app name" failed.' Plugins configuration is same, they're using same otk/pfc dependency, same java version for compilation and same Creo 7 instance.
I've found this article but most of points are not suitable as other two plugins are running properly. Is there a more detailed log file of creo application startup to see any detailed information what goes wrong when starting plugin? Any other idea how to debug/investigate it?
Thank you very much.
Sorry for a late answer - I forgot on it 🙂 Finally I was able to run the stuff by locating all libraries in one folder (with OpenJFX libs too) and adding plugins dependencies directly via Creo management tool configuration instead of manual records in configuration file. Now it is working and all plugins are running.
I hope you tried starting only 1 problematic application.
If you are active customer then you can contact PTC Support.
Yes, I tried several ways, even starting it separately, but no success yet. Juraj
my suggestions:
1.] cut the application code, compile it and test it
If it works then return part of the program code -AND- repeat the same procedure.
If it does not work then cut part of the program code -AND- repeat the same procedure.
2.] send the code to PTC Support and ask them to test it
I am not sure if PTC Support will help you because Creo 7.0 is not supported anymore.
