Apr 26, 2011 5:41 PM UTC
JLink - setting text color to standard system color
- 1 reply
- 819 views
- Translate All
I am trying to create a jlink application to modify all text on a specific layer to the "Highlight - primary" (StdColor COLOR_HIGHLIGHT) system color. So far, I have only been able to set the text color to the same ColorRGB values as COLOR_HIGHLIGHT. The problem with this is that ProE sees it as a "user defined" color and therefore it does not print according to the pen table. Is there a way to set the text color to StdColor COLOR_HIGHLIGHT? I'm using Wildfire 5.0 M080. My code is attached below.
Mary Mitchell
