Feb 6, 2015 9:56 AM UTC
Keyboard shortcut for switching to/from model tree
anyone knows whether there is a keyboard shortcut for switching from the graphic model area to the model tree in the right column? (instead of using the mouse).
(I only know there is a command, the key Q, which hides/shows the right column... there must be also one to do this switching...)
thanks
    Feb 17, 2015 9:55 PM UTC
    I haven't understand what you are trying to do, but try this mapkey:
    mapkey x ~ Command `ProCmdLocateInMdlTree`; ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree`;
    Just paste it in your config.pro, restart Creo and call mapkey "x"
    Jose
    Feb 6, 2015 2:07 PM UTC
    mapkey x @MAPKEY_NAMEHIDE TREE;@MAPKEY_LABELHIDE TREE;\
    mapkey(continued) ~ Command `ProCmdEnvModelTree` 0;
    tleati12-AmethystAuthor
    Feb 6, 2015 2:14 PM UTC
    Hallo Syndakit,
    thanks for your reply but I am not an expert-user, could you explain better what you wrote?
    thanks
    Bye
    Feb 6, 2015 2:16 PM UTC
    Sure,
    so let me make sure i understand what you want.
    you want your model tree to be able to toggle visible/hidden correct?
    Jose
    Feb 20, 2015 10:17 PM UTC
    Or Shift+Tab Seems to work too .
    Feb 24, 2015 8:44 AM UTC
    thank you, that is quite what I was looking for and both the commands you gave me work.
    The only thing I am afraid not to be able to do is switching back to the 3d model, but anyway it's a good thing to have already the other way working.
    thanks again,
    Bye!
