Launch creo parametric at a specific location on the screen
is possible launch creo parametric at a specific location on the screen?
I use windows_scale 0.5 and the window moves to the top left.
I would like to open more at the top right, down left & down right.
I did it.
To activate the last session icon I have to open at least one file or create a new one, save it and close the CAD.
Next time I start CAD I can recover the last session.
Grazie
C_Spagnolli,
Not specific to PTC, but many desktop managers can do this.  NVIDIA has nView Desktop Manager for example.
Dan N.
RPN
18-Opal
Restore last session, may do that for you as far I know, but from start you have probably to code.
I tried but I can't.....
I use many files config.pro and file_start.ink
How do I save last sessions for use?
RPN
18-Opal
Check that you have the config.pro option last_session_retrieval set to Yes
There is also an option where this is stored, for this check  "last_session_directory_path"
Hi.
I tested Creo 9.0.2.0:
  • start session
  • change window size ... information is save somewhere
  • change window position ... information is save somewhere
  • end session
When I started next session, window size & position was restored.
