Jan 30, 2025 5:31 PM UTC
Leave CREO PTC with two languages
Hello
I would like to know if it is possible to leave CREO with two languages, when it opens I can select which one I want.
Jan 30, 2025 8:28 PM UTC
This is described in Article CS147730
Let's assume you want English and German.
Locate your parametric.psf file under <Creo load point>\Parametric\bin.
Make a copy of parametric.psf and name it parametric_g.psf
Edit parametric.psf: Change the DESC line like this : DESC=Creo Parametric - English
At the end of the file add the following line
ENV=PRO_LANG=english
Edit parametric_g.psf.
Change the DESC line like this : DESC=Creo Parametric - German
ENV=PRO_LANG=german
When you start Creo you should see a dialog box like this:
ENV=PRO_LANG=german
RPN
18-Opal
Jan 30, 2025 9:26 PM UTC
You nailed it. I thought about to change at run time. Your answer is quite short and perfect in my point o.v. 😉
