18-Opal
Jun 4, 2018 9:22 AM UTC
Link not visible in project properties
I want to read data from Excel and use it as a filter.
Or to read the value of a specific parameter or directory address.
C is asking me to set up a link while browsing the library that reads xlsx or xlx.
However, if the project configuration properties are makefiles, no links are visible in the options.
CHASEONHO18-OpalAuthor
18-Opal
Jun 7, 2018 2:28 AM UTC
add the LIB path to the makefile, the build succeeds.
However, the toolkit application does not run.
