List dimensions using jlink
JLink fails to list dimensions. I created a part in Creo Parametric, 4.0 and then created a drawing from that part There are 10 shown dimensions. I want to get a list of them using jlink. I use the following line of code to get them:
ModelItems dims = drawing.ListItems(ModelItemType.ITEM_DIMENSION);
but when I query the array size, it says "size=0".
int size = dims.getarraysize();
printMsg("size="+size);
Anybody have a clue to what is going on?
Here is more of the code which is derived from jlink exercise 1 (C:\Program Files\PTC\Creo 4.0\M030\Common Files\otk_java_free\exercises\exercise_1_and_2) and C:\Program Files\PTC\Creo 4.0\M030\Common Files\otk_java_free\otk_java_appls\jlinkexamples\pfcDrawingExamples.java.
public void getModelInfo(int index) throws jxthrowable
Vector data_i;
Model model;
/* Model data */
String name;
ModelType type;
String typeString;
model = models.get(index);
data_i = new Vector (10);
/* Get model full name */
name = model.GetFullName();
printMsg("Getting information from model: "+name);
data_i.addElement(name);
/* Get model type */
type = model.GetType();
typeString = Labeler.pfcModelType[type.getValue()];
if (typeString.equals("MDL_PART") || typeString.equals("MDL_ASSEMBLY")) {
else if (typeString.equals("MDL_DRAWING")) {
   Drawing drawing = (Drawing) model;
   //Dimension2Ds dims = drawing.ListShownDimensions(model, ModelItemType.ITEM_DIMENSION); //get a "method is deprecated" error message if I use this!
   for (int i=0; i<dims.getarraysize(); i++) {
      printMsg("about to dims.get("+i +")...");
      Dimension2D dim = (Dimension2D)dims.get(i);
      int dimId = dim.GetId();
      String dimName = dim.GetName();
      double dimValue = dim.GetDimValue();
      String s = String.format("%d, %s, %.2f", dimId,dimName,dimValue);
      printMsg(s); //nothing is printed since array size=0
modelData[index] = data_i;
return;
tekknowAnswer
Hi Martin,
Yes, you were right.  The dims belonged to the part, not the dimension.  I created a separate linear point-to-point dimension in the drawing and then that dim showed up.
Thank you,
Greg
I guess that your code is not able to find shown model dimension. To test my guess, try to create drawing dimensions and run your application. I hope that it will find them.
Unfortunatelly I cannot tell you how to find shown model dimension 😞
tekknow1-VisitorAuthorAnswer
Hi Martin,
Thank you,
Greg
your code can find drawing dimensions whose symbol names are add0, add1, and so on.
To be able to create such drawing dimensions you have to set following config.pro option
CREATE_DRAWING_DIMS_ONLY yes
Only these dimensions are saved in drawing - this means drawing is their parent.
Drawing dimensions whose symbol names are ad0, ad1, and so on are saved in drawing model - this means drawing model is their parent.
Hi Martin,
I do have the config.pro option set as
create_drawing_dims_only yes
I was expecting that after I had set that option and then re-opened the model in Creo and did a Save, that any dimensions belonging to the part would now belong to the drawing.  But that was not the case.  It seemed to make no difference.  What does that option do?
Greg
Ps.
Is Dimension2D obsolete? I'm trying to get a list of drawing dimensions and associated attributes. I loop through the session models and if it is of type MDL_DRAWING, I cast it to Drawing and attempt to list it's dimensions using the following command:
but I get the following error:
exception caught: com.ptc.wfc.Implementation.pfcExceptions$XToolkitObsoleteFunc
I can successfully collect the dims if I instead use the following command:
I then loop through the ModelItems using the following command:
ModelItem item = dims.get(i);
but the available methods in ModelItem are not as extensive as in Dimension2D. For example Dimension2D has a Location method which I need to distinguish between two dimensions of the same type that have the same nominal value.
Is Dimension2D obsolete? If so, what replaces it to get all the same methods? If not, how to make it work?
following code enables me to get drawing dimensions whose symbol names are ad0, ad1, ... and also d0, d1, ...
proeModel = proeSession.GetCurrentModel();
Drawing drawing = (Drawing) proeModel;
Models drawingModelList = drawing.ListModels();
// my drawing has 1 model only ... I get this model using drawingModelList.get(0)
Model2D myModel2D = (Model2D) drawing;
Dimension2Ds drawingShownDimensions = myModel2D.ListShownDimensions(drawingModelList.get(0),ModelItemType.ITEM_DIMENSION);
int i2 = drawingShownDimensions.getarraysize();
for (int i=0; i < i2; i++)
  pw.println("about to dims.get("+i +")...");
  Dimension2D dim = (Dimension2D)drawingShownDimensions.get(i);
  // command to print dimId + ", " + dimName + ", " + dimValue
