List of Creo Colors
Hi All,
Is there a thread where I can find a list of different system colors that I can download? Looking for an easy way to grab .scl files with already made color configs.
Thanks in advance!
KenFarley
Why don't you just search for it?
Regardless, this is the stuff from one of my old syscol.scl files:
blended_background no
system_background_color 0.000000 0.000000 0.000000
system_dimmed_menu_color 70.000000 70.000000 70.000000
system_bottom_blending_color 0.000000 6.000000 20.000000
system_curves_color 0.000000 90.000000 90.000000
system_datum_color 60.000000 45.000000 0.000000
system_edge_high_color 0.000000 0.000000 100.000000
system_geometry_color 100.000000 100.000000 100.000000
system_hidden_color 40.000000 40.000000 40.000000
system_highlight_color 60.000000 0.000000 20.000000
system_letter_color 100.000000 100.000000 0.000000
system_presel_highlight_color 50.000000 20.000000 20.000000
system_preview_geom_color 100.000000 75.000000 0.000000
system_quilt_color 60.000000 0.000000 70.000000
system_secondary_preview_color 70.000000 70.000000 70.000000
system_secondary_selected_color 100.000000 50.000000 0.000000
system_section_color 100.000000 72.000000 30.000000
system_selected_color 80.000000 0.000000 0.000000
system_shaded_edge_color 0.000000 0.000000 0.000000
system_sheetmetal_color 30.000000 100.000000 30.000000
system_top_blending_color 0.000000 35.000000 60.000000
system_volume_color 100.000000 0.000000 100.000000
ui_background_color default
ui_editable_area_color default
ui_selected_area_color default
ui_selected_text_color default
ui_text_color default
use_pre_wildfire_entity_color no
alias_dtm_pln_color_to system_datum_color
alias_dtm_pln_tag_color_to system_dimmed_menu_color
alias_dtm_axis_color_to system_datum_color
alias_dtm_axis_tag_color_to system_dimmed_menu_color
alias_dtm_pnt_color_to system_curves_color
alias_dtm_pnt_tag_color_to system_dimmed_menu_color
alias_coord_sys_color_to system_datum_color
alias_coord_sys_tag_color_to system_dimmed_menu_color
alias_sec_dim_strong_color_to system_letter_color
alias_sec_dim_weak_color_to system_hidden_color
Unfortunately, as you will find, the colors used throughout Creo are undocumented and a somewhat arcane thing. I've tried to set up a "nice" color scheme only to find that colors I thought went with specific functions are actually from somewhere else, and the inability to select certain types of things wouldn't be visible, etc.
Testing changes is also not a lot of fun.
All in all, I found messing about with the color schemes a bad experience.
DomenicLaritz
The following four colors are missing from your listing:
  • SYSTEM_BOTTOM_LEFT_BLENDING_COLOR
  • SYSTEM_BOTTOM_RIGHT_BLENDING_COLOR
  • SYSTEM_TOP_LEFT_BLENDING_COLOR
  • SYSTEM_TOP_RIGHT_BLENDING_COLOR
By the way, you mentioned system_dimmed_menu_color twice.
KenFarley
Like I said, this is stuff from old syscol.scl files. I just dumped out what I had - it's a list of stuff others before me have modified and kludged together. Duplicates? Nice to know, but presumably the last setting is the one that wins. I've ferreted out the same sort of thing in config.pro files, too.
As for the blending colors, even if I'd known about them I wouldn't use them. I find the blended background terribly annoying. I'm a solid black background person. The blended stuff is terrible especially if I'm going to grab an image from the screen and then edit it to make the background transparent, etc. If there are a bunch of shades of colors it is difficult if not impossible to pick just the background to remove it. Plus, to be honest, I don't like the blended stuff to begin with.
