Listing Components FeatureIDs
Hello PTC Community,
I hope this message finds you well.
I am working on a project where I need to generate a list of all components and datum planes via WebLink. The list should have three columns:
Column 1: Component name /Datum Plane name
Column 2: All available featureIDs for each component (I have attempted this with pwlMdlFeaturesGet but haven't been successful)
Column 3: Identification of whether it is a datum plane, prt, or asm
Here is my current code:
<script language="JavaScript">
try
 if (pfcIsMozilla())
 netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect");
 wpwl = pfcGetScript ();
 document.pwl = wpwl;
 wpwlc = wpwl.GetPWLConstants ();
 document.pwlc = wpwlc;
 wpwlf = wpwl.GetPWLFeatureConstants ();
 document.pwlf = wpwlf;
catch (err)
 alert ("Exception caught: "+pfcGetExceptionType (err));
function WlModelGetBOM() {
 var table = document.getElementById("bomTable");
 table.innerHTML = ""; // Clear previous content
 var ret = document.pwl.pwlMdlCurrentGet();
 if (!ret) {
 alert("Error retrieving current model");
 return;
 var modelNameExt = ret.MdlNameExt;
 var retDeps = document.pwl.pwlMdlDependenciesGet(modelNameExt);
 if (!retDeps.Status) {
 alert("pwlMdlDependenciesGet failed (" + retDeps.ErrorCode + ")");
 return;
 // Create table header
 var headerRow = table.insertRow();
 var modelNameCell = headerRow.insertCell(0);
 modelNameCell.innerHTML = "<b>Model Name</b>";
 var FeatureIDCell = headerRow.insertCell(1);
 FeatureIDCell.innerHTML = "<b>Feature ID</b>";
 var FeatureCell = headerRow.insertCell(2);
 FeatureCell.innerHTML = "<b>Feature</b>";
 var models = [];
 for (var i = 0; i < retDeps.NumMdls; i++) {
 var modelName = retDeps.MdlNameExt.Item(i);
 var FeatureID = "FeatureID";
		var Feature = "Datum/ASM/PRT";
 models.push([modelName, FeatureID, Feature]);
 // Sort models (by model name)
 models.sort(function(a, b) {
 return a[0].localeCompare(b[0]);
 // Add models to table
 for (var i = 0; i < models.length; i++) {
 var row = table.insertRow();
 var cell1 = row.insertCell(0);
 var cell2 = row.insertCell(1);
		var cell3 = row.insertCell(2);
 cell1.innerHTML = models[i][0];
 cell2.innerHTML = models[i][1];
		cell3.innerHTML = models[i][2];
</script>
I would greatly appreciate any guidance or suggestions on how to achieve this.
Thank you in advance for your support!
Best regards,
Fred
