Apr 21, 2017 12:47 PM UTC
Load a model in a session
I have a Model and i stored in my computer.Ex(C:\Desktop\load.prt)
In my proE session i involved a GUI.Where user can do some works.Here what i want is,I want to load a model that stored in C:\Desktop\load.prt  when user clicks the button .Can please any one tell me how to do this?
sjurajAnswer
Apr 24, 2017 6:58 AM UTC
RetrieveModel only puts model into session. However RetrieveModel ignores path. You have to use RetrieveModelWithOpts method instead. Note to use right path to your file. There is no such path as c:/desktop/xxx.prt. Path to desktop is always c:/<user_name>/desktop. This code will load model from path to session and than displays it in the new created window.
ModelDescriptor md = pfcModel.ModelDescriptor_CreateFromFileName("c:/users/<user_name>/desktop/xxx.prt");
RetrieveModelOptions rmo = pfcSession.RetrieveModelOptions_Create();
rmo.SetAskUserAboutReps(false);
Model model = session.RetrieveModelWithOpts(md, rmo);
Window window = session.CreateModelWindow(model);
model.Display();
window.Activate();
Apr 22, 2017 6:23 AM UTC
You can simply run macro and replace model name in macro string using method session.RunMacro
Apr 22, 2017 2:56 PM UTC
Use Retrieve model function to load the model in session
Use Model Descriptor to set the file name
You have to set the location as working directory
ddhini1-VisitorAuthor
Apr 24, 2017 4:30 AM UTC
Can you please explain it through coding?
Apr 24, 2017 5:03 AM UTC
Models char* _ProMdlRetrieve(wchar_t* FileName, int Type)
       char* msg;
       ProError Magizchi;
       ProMdlType modelType;
       switch(Type)
       case 0:
              modelType = PRO_TYPE_UNUSED;
              break;
       case 1:
              modelType = PRO_ASSEMBLY;
              break;
       case 2:
              modelType = PRO_PART;
              break;
       case 3:
              modelType = PRO_DRAWING;
              break;
       case 4:
              modelType = PRO_MDL_3DSECTION;
              break;
       case 5:
              modelType = PRO_2DSECTION;
              break;
       case 6:
              modelType = PRO_LAYOUT;
       case 7:
              modelType = PRO_DWGFORM;
              break;
       case 8:
              modelType = PRO_MFG;
              break;
       case 9:
              modelType = PRO_REPORT;
              break;
       case 10:
              modelType = PRO_MARKUP;
              break;
       case  11:
              modelType = PRO_DIAGRAM;
              break;
       ProMdl p_model;
       Magizchi = ProMdlRetrieve(FileName, modelType, &p_model);
       switch(Magizchi)
       case PRO_TK_NO_ERROR:
              msg = "Model Retrieved";
              break;
       case PRO_TK_BAD_INPUTS:
              msg = "One or more of the input arguments are invalid";
              break;
       case PRO_TK_E_NOT_FOUND:
              msg = "The model was not found in the current directory";
              break;
       case PRO_TK_NO_PERMISSION:
              msg = "The function does not have permission to handle this model";
              break;
       return msg;
Now call the method
_ProMdlRetrieve(FileName(wchar_t*), FileType(int))
You can also use out to hold the model data
Apr 26, 2017 10:53 AM UTC
But how to load the both drawing and model ? I load the master model into my session by the above code that you suggested.I have a master drawing file also.But i can't able to load it in a new session.
Apr 26, 2017 10:55 AM UTC
ModelDescriptor md = pfcModel.ModelDescriptor_CreateFromFileName("C:\\Users\\350154\\Desktop\\javaGUI\\modelgen\\dist\\mastemodels\\xxxx.drw");
  Drawing drw = (Drawing) session.RetrieveModelWithOpts(md, rmo);
  Window window = session.CreateModelWindow(drw);
  drw.Display();
  window.Activate();
But its failed to load the drawing file.
Apr 26, 2017 11:22 AM UTC
You have not retrieved the part/asm. This code will open drawing in new activated window.
final String modelName = "test";
final String path = "c:/users/xxx/desktop/";
ModelDescriptor modelMD = pfcModel.ModelDescriptor_CreateFromFileName(
        path + modelName + ".prt");
ModelDescriptor drwMD = pfcModel.ModelDescriptor_CreateFromFileName(
        path + modelName + ".drw");
session.RetrieveModelWithOpts(modelMD, rmo);
Drawing drawing = (Drawing) session.RetrieveModelWithOpts(drwMD, rmo);
Window drwWin = session.CreateModelWindow(drawing);
drawing.Display();
drwWin.Activate();
Apr 26, 2017 12:45 PM UTC
Toolkit error is arising.. but don't know why it is arising.
Apr 26, 2017 12:51 PM UTC
Try to solve it. I cant help you more. This works for me.
Apr 26, 2017 12:52 PM UTC
Thank you so much for your help skvarka juraj‌
