Apr 29, 2015 11:44 AM UTC
Macro
Hi!! I am making static simulations and doing a lot of analisis, I´m chaging the geometry and checking the displacement and mass of the edited part. Since I´m doing a lot of analisis, I wanted to know if there is a way in Creo to connect a programming Software like Matlab or Visual Studio to use a macro or programm that could Analyse and document the results from the analisis?
Thanks a lot.
Best regards,
Edna
Chris3
Chris3Answer
May 5, 2015 12:56 PM UTC
If it was just a single number then it will show up in the results dialog box along with max_stress_vm and all of the other default measurements. If it has multiple data points then you need to open it as a measure. Change the display type to Graph and the QTY to measure. Then it will show the result as a graph that you can export to Excel.
Chris3
Apr 29, 2015 12:19 PM UTC
I am not sure what kind of results you are referring to, but a lot of the Creo Simulate results can be exported to a text file our a csv, xls for graphs. Depending on what you are trying to do, you could create a mapkey to automate exporting the results to a text file and then open it as desired in an external program.
May 4, 2015 1:13 PM UTC
hi Christopher,
thanks a lot for your answer. That would be very helpfull, I would like to export this results to an xls. how could I do this?
May 4, 2015 1:22 PM UTC
since when I select save as, the only type option that appears is .rwd
