Feb 14, 2018 12:05 PM UTC
Macro not working using ProToolkit
I'm using the function "ProMacroLoad(L"~ Command `ProCmdModelProperties`");" to invoke model properties dialog box using ProToolKit (C language). But the dialog is not showing up when I use the function.
where as when i try "ProMacroLoad(L"~ Command `ProCmdModelNew`");" it shows a dialog box successfully.
Can any one help me out in opening the "Model Properties" dialog using ProToolKit?
Feb 15, 2018 8:30 AM UTC
Are you building your application to be "synchronous" or "asynchronous"?
There are some rules for Toolkit regarding mapkeys that vary depending on which method you are using.
Also, are there other mapkey lines you are running surrounding this one? or is it just this line?
Are you also using ProMacroExecute at the end of your method?
James Sullivan
zynkana1-VisitorAuthor
Feb 19, 2018 6:20 AM UTC
Thanks for your response.
Even though I'm using ProMacroExecute() after ProMacroLoad() macro is not executed.
2-Explorer
Feb 20, 2018 7:17 AM UTC
If we write a line in trail file "~ Command `ProCmdModelProperties`" and run it, it doesn't show property page window.
~ Command `ProCmdMmModelProperties` works in case of playing trail file, but not with macro load.
I suppose it is not possible to activate model property window using macro.
Reason behind my conclusion is that macro did not work for following steps also:
~ Activate `mdlprops_dlg` `ACCURACY_lay_Controls.push_Change.lay_instance`
~ Activate `setup_accuracy_dlg` `pushbt_Cancel`
Above steps are used to open accuracy page and close it without changing value, which ends up having property page dialogue being displayed to us.
