May 22, 2017 10:42 AM UTC
Manually run the database server
I would like to run database server manually. How do I manually run the database server?
I understand that C: \ Program Files \ PTC \ Creo Elements \ DirectShow Server 19.0 \ servwin \ me_dserv64_ole.exe "works in the background.
I need the parameters of this me_dserv64_ole.exe file.
I am waiting for your help in this regard.
Thanks in advance.
Sonat Elmaci
Jun 1, 2017 12:00 PM UTC
The "Database Server" (me_dserv64_ole.exe) is running as a *Service*.
You never run this as anything else.
You need a Client (e.g. Model Manager) to access the Database - if you have a Model Manager Database.
Do you have client licenses at all?
selmaci1-VisitorAuthor
Jun 1, 2017 2:08 PM UTC
Thank you for your answer. Yes, I have model manager license.
I got an error message when I setup Creo Elements Direct Manager Server 18 and installation is canceled.
I complete the setup with manually. I have to manually run the Software Distribution Server (apache web server).
Therefore I can not use  Job Spooler server (task manager).
If I do not choose the database server in the software setup, I use Job Spooler server successfully.
But this time I can not run the database server. Therefore I would like to run database server manually.
Or I need to run Job Spooler manually.
Jun 1, 2017 2:47 PM UTC
For a Model Manager database, a Database Server, File Server and License Server are REQUIRED.
If any of the three mentioned servers (=services) is not installed and running, you can neither run a Model Manager client
nor any other additional service like Software Distribution Server, Job Server etc.
I recommend you get in touch with a consultant who has experience with a Model Manager installation.
