Mark Deprecated Script Marked a Replacement as NONE
When I ran the mark deprecated script from Creo 9 on my Creo 5 toolkit files, one of the suggestions I got was "Replace ProGtolDataGet with NONE." Is NONE a function? or is it telling me that it has no suggestion to replace this function with?
There is no successor function as the workflow changed. While it was previously necessary to call ProGtolDataGet and then call other ProGtoldata*() functions to extract information from that Gtoldata, you can now use new functions to directly manipulate the ProGtol item.
Example for getting the type of a ProGtol:
ProGtol my_gtol; // lets pretend it's pointing to a valid item
ProGtoltype type; // that's what we want to get
Old workflow
ProGtoldata data;
ProGtolDataGet(&my_gtol, &data);
ProGtoldataTypeGet(data, &type);
ProGtoldataFree(&data);
New workflow
ProGtolTypeGet(&my_gtol, &type);
So the replacement of ProGtolDataGet depends on what you're actually doing with the gtol. Use the new functions to achieve the same goal as before.
Old workflow
ProGtoldata data;
New workflow
Ah, I see, thank you for the help
